Tsubaki cable towing
Solid steel chains for horizontal drilling rigs
Robust steel cable drag chains from Tsubaki Kabelschlepp are suitable for horizontal drilling rigs, among other things, which enable the trenchless laying of pipelines over long distances. The company produces the energy chains as customized standard solutions.
© Tsubaki cable towing
The cable drag chains are attached to the side of the masts of the drilling rigs and guide or protect the hydraulic hoses there. The S-series steel chains from Tsubaki Kabelschlepp are ideal for this application. The robust and heat-resistant steel solutions were designed for heavy mechanical loads and harsh production environments and, according to the manufacturer, are also the ideal choice for drilling rigs. The steel chains are individually fine-tuned to meet the specific requirements of each project. Modifications primarily relate to optimum utilization of installation space and a particularly stable design of the chain, including in the interior - specifically in the area of the separators, which, like the chain links themselves, are made of steel. Tsubaki Kabelschlepp also designs adapted connecting elements and adjusts the pre-tension of the chain to enable a long unsupported length of chain despite the high cable weight of the hoses.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
