Sagittarius
Completely tool-free installation
Lütze has optimized the well-known 'LOCC-Box' family for electronic load monitoring in terms of simplified installation, connection technology and control cabinet performance. The upgrade enables the LOCC-Box to be installed in the control cabinet completely tool-free.
The 'LOCC-Box' from Lütze for electronic load monitoring
© Sagittarius
Instead of the spring-loaded terminals usually used, Lütze relies on push-in technology and therefore offers a significantly larger terminal cross-section. Wire cross-sections up to 2.5 mm² with and without ferrules can be connected. Ergonomically arranged blue actuators make it easy to remove the wires. The new modules have a test opening, while the familiar slot for the jumper system continues to reduce wiring work.
The device housing has been slimmed down by a total of 8 mm for even more space and freedom of flow in the switch cabinet. A spring integrated into the module base improves the hold so that the LOCC box sits securely on the DIN rail, according to the manufacturer. Other new features include the rounded design and additional LED functions that provide information on actual and target settings. The new modules are compatible with all previous models and will be available from the first quarter of 2022.
Background: The LOCC box (Lütze Overload Current Control) is used for intelligent overload and short-circuit monitoring. Thanks to its patented tripping behavior along defined characteristic curves, it enables the creation of selective power supplies. In the event of a fault, only the affected circuits are switched off. The system saves faults and thus prevents the same cause of fault from reoccurring the next time it is switched on. Fault diagnosis is carried out via the hardware itself or via gateways to various fieldbus systems.
Sagittarius
Climate-friendly planning
How can an enclosure be operated in an energy-efficient manner at any time of year without risking thermally induced failures? There is great potential in the combination of different cooling mechanisms through intelligent control. One example.
SPS 2021
E-Paper: THE OFFICIAL DAILY Day 1
SPS 2021 was to take place in a hybrid trade fair format for the first time, but the current coronavirus situation made a real trade fair experience impossible. But you don't have to miss out on news about the industry get-together.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
