Conec
Colored plastic cover elements
Conec has expanded its product portfolio of overmoulded M12x1 connectors to include variants with colored plastic overmoulding elements.
© Conec
The option to choose between the color variants (black, white, yellow, red, blue, green) makes it easier to assign complex cabling. The connection cross-section is up to 0.75 mm². The plastic material used is resistant to weak acids, bases, alkalis and alkaline cleaning agents and, according to Conec, is therefore particularly suitable for areas of application in which the chemical environment does not permit the use of zinc die-cast fittings.
Typical application examples include dosing pumps for the treatment of drinking water, waste water and industrial water, dosing systems and disinfection systems for industrial use as well as applications in the agricultural sector.
Yamaichi
Board-to-cable systems
The Y-Lock series is a board-to-cable system and, based on the non-ZIF principle, offers a locking mechanism that works without opening or closing a flap or drawer and without operating an unlocking mechanism.
Vahle
Energy supply for shuttle, AKL and RBG
Paul Vahle launches the VCL compact conductor rail. The solution was designed for shuttle systems, automated small parts warehouses (AKL) and storage and retrieval machines (RGB) as well as for compact shuttle and transfer trolley applications in...
