Plug connector
Built flat
With the 'Roboticline' Robifix-Mini connector, Multi-Contact is presenting another solution for high-frequency welding technology: The compact design of the connector simplifies integration into modern lightweight construction concepts.
The smallest connector in the 'Robifix' family can be assembled by hand and has dimensions of 80 mm × 30 mm × 140 mm. It is designed for 16 mm², 25 mm² and 4 AWG. Thanks to its flat design, it can be used for mounting on robot arms and as a hand-held connector. In addition to applications in the frequency range from 50 to 3000 Hz, the connector can also be used in new technologies up to 10 kHz. The integrated contact protection increases safety.
