Stäubli
Development environment optimized
Stäubli has equipped the Robotics Suite 2022 with optimized and new features that cover all fields of application - from design, simulation and commissioning to production and optimization.
The Robotics Suite from Stäubli
© Stäubli
The so-called Snap Replace function simplifies the transition from the static design environment to the dynamic development environment. Components can be selected from an integrated component catalog. If a component is selected from the component catalog, it can be dragged and dropped to the desired position in the 3D layout. The snap function is used to position objects (components) or to move the robot to a desired position without having to create position variables in advance. Screen recording is integrated into the Stäubli Robotics Suite 2022. By pressing a record button, every work step within the development environment can be recorded and then sent to customers as an mp4 file. An integrated control panel supports the user in optimizing processes and movements during the simulation.
Stäubli
Plug connector for 24 V(DC)
The 24 V (DC) supply voltage is becoming increasingly important in automation technology. For a reliable power supply, continuous wiring with a conductor cross-section of 2.5 mm² is required.
