Stäubli
Inserts from rough to sterile
Stäubli is launching three new six-axis robots for the medium payload range. The TX2-140, TX2-160 and TX2-160L models complete the TX2 generation.
© Stäubli
The standard version of the TX2-160 can reach 1710 mm, while the TX2-160L long arm version has a reach of 2010 mm. The reach of the TX2-140 is 1510 mm. The load capacity of the TX2-140/160 is 40 kg in each case; this value is reduced to 25 kg for the long arm version.
Stäubli specifies a repeat accuracy of ±0.05 mm for all three models. In combination with their dynamic values - for example, the maximum speed is 1500 °/s in axis 5 - the shortest cycle times can be realized. The models are compact and designed for cleanroom suitability: They have no external cable and hose package, but internal media and supply lines without interfering contours and a completely sealed housing with protection class IP65 (optionally with overpressure unit IP67).
Stäubli
Plug connector for 24 V(DC)
The 24 V (DC) supply voltage is becoming increasingly important in automation technology. For a reliable power supply, continuous wiring with a conductor cross-section of 2.5 mm² is required.
Special
Robotics&AUTOMATION 1/2021
The latest Robotics&AUTOMATION special is here! The e-paper provides you with practical information on current trends and developments - as well as first-hand information on the extent to which robots can secure Germany as a technology location.
Robotics
Goodbye lines of code!
Fuzzy Logic Robotics is announcing the first version of the Fuzzy Studio software platform for the Hannover Messe 2021 - a product designed to enable robots to be used more flexibly in production.
Kuka at Infineon
Cobots automate cleanroom
At Infineon's semiconductor production facility in Villach, 17 sensitive lightweight robots from Kuka work safely together with humans and machines to ensure greater efficiency and safety in the manufacture of highly fragile wafers.
