iC House at the SPS 2021
For certified safety encoders up to SIL3/ PLe
iC-RB from iC-Haus is an optical twin-scan encoder IC with an absolute resolution of 24 bits in the control channel and 15 bits in the safety channel.
© iC House
It can be used stand-alone - without external interpolation for high-resolution safety encoders. The absolute encoder IC has two separate and independent channels so that it meets the high redundancy requirements of functional safety concepts up to SIL3 or PLe for position detection. It can be used in particular for SIL encoders and motor feedback systems with single or multiturn function. Code disks with a diameter of 26.5 to 42.5 mm are supported. The encoder IC scans a 10-bit pseudo-random track (PRC) on the code disk via two autonomous channels. In addition, two high-resolution phased array photo sensors read an incremental track with 1024 cycles per revolution. The sin/cos signals generated in this way are used for on-chip interpolation to increase the resolution. Control Channel and Safety Channel offer a BiSS slave interface, which is compatible with the BiSS safety protocol, and an SSI master multiturn interface.
iC-Haus at the SPS 2021: Hall 4A Stand 136
Kübler
Data collector Rotary encoder
At its annual press conference, Kübler looks back on the current financial year with satisfaction. One of the company's key innovations: encoders with direct communication to the Ethernet network.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
