ifm at the Hannover Messe
Robust cube-shaped sensor
With 'PQ Cube', ifm electronic is launching a pressure sensor with industrial-grade properties onto the market. Typical applications include the control of vacuum grippers for handling tasks, the monitoring of pneumatic cylinders and general pneumatic applications.
The cube shape with an edge length of 30 mm has become the standard for sensors in pneumatic applications. The PQ Cube from ifm corresponds to this form factor and offers advantages during installation and operation such as simple mounting without accessories, a fully graphic display for visualization and a robust measuring cell that can withstand adverse environmental conditions. The measuring cell with IP65 protection is resistant to dust and oily compressed air.
The fully graphic TFT display enables visualization in the application. In addition to the current value, a color change at the switching point shows directly and clearly whether the pressure at the measuring points has reached the switching point. An additional info line can display further status information in plain text. Two additional LEDs also signal that the switching points have been reached. The display is helpful when installing the sensor, which is done using three buttons. The display shows the parameterization in one of the nine available languages while the user uses the installation wizard. Users can manage without additional accessories in most installation situations. Cut-outs in the housing allow the sensor to be attached at the back or side with screws. It is available in different versions with pressure ranges from negative pressure to 16 bar. All devices are available with M8 plugs, variants with M12 plugs are in preparation.
Hall 9, Stand D36
