Pepperl+Fuchs
Heat-Resistant with Long Switching Distance
The high-temperature inductive sensors of the ‘NBN...-F135’ series from Pepperl+Fuchs offer a switching distance of up to 50 mm. The integrated IO-Link interface in the amplifier allows integration into Industry 4.0 applications.
© Pepperl+Fuchs
Sensors are available with variable cable lengths, and each component can be replaced individually. The inductive sensor sets can be used at temperatures up to +250°C, and the switching distance drift is typically below 5%. Sensor heads can be replaced without re-parameterization of the amplifier, and adjustment of the switching distance via potentiometer is unnecessary. The IO-Link interface enables continuous communication between control and field levels, including sensor head status and limit warnings for predictive maintenance. Additionally, a switch cycle and operating hour counter is integrated. Multiple sensor heads can be synchronized—both in SIO and IO-Link modes—when arranged in series. The devices are available with fixed cables or a detachable connector, with cable lengths between 1 and 30 meters to facilitate installation. Flush mounting on metal minimizes the risk of sensor head damage.
