Pepperl+Fuchs
Uncomplicated into the IIoT
Pepperl+Fuchs and Bosch will present the 'IoT Starter Kit Bosch' using a trade fair model. © Pepperl+Fuchs
A highlight exhibit at the Pepperl+Fuchs booth is a joint project with Bosch Digital Twins Industries and Syntax. Matthias Wieland from Bosch Digital Twin Industries and Hans-Günter Busch from Pepperl+Fuchs reveal the details of the predictive maintenance solution.
Hans-Günter Busch is NBD Technology Manager for Industrial Communication at Pepperl+Fuchs. © Pepperl+Fuchs
Mr. Busch, what kind of joint project is this?
Hans-Günter Busch: The project is the digital twin of a pipeline conveyor system - a real project that is simulated with our trade fair exhibit. The system solution presented here shows visitors the modular structure of this application. Pepperl+Fuchs supplies the sensors, including the infrastructure components for communication, while Bosch Digital Twins Industries takes care of system integration based on tools and services from the AWS IoT Core. Users have the option of making the data obtained accessible to their ERP system - in this case, Syntax Systems would come into play as an additional partner.
What can trade fair visitors see at the stand?
Hans-Günter Busch: Firstly, Pepperl+Fuchs will be presenting the hardware required, i.e. the sensors for recording the necessary process data, including the infrastructure components for communication at field level - for example a vibration sensor with an IO-Link interface and BLOB functionality. The process data is collected with a multi-link-capable IO-Link master. The model enables communication via Industrial Ethernet and, at the same time, vertical communication via MQTT or OPC UA. In this case, a box thin client serves as the edge gateway.
The vibration, flow and pressure data generated in the model is collected in an AWS database. With the help of tools and services from the AWS IoT Core - for example Amazon Kinesis, AWS Lambda, Sagemaker or Twinmaker - Bosch takes care of system integration and cloud-based data analysis. A digital image of the system is used to feed the recorded data into a simulation model in real time. Based on statistically recorded data and the principles specified by the system operator in conjunction with the simulation model, prediction including recommendations for action is now possible in order to ensure the best possible availability of the system.
We have combined the aforementioned products, including the Bosch system solution, in an IoT starter kit. To round off the solution, we also offer optional integration into an ERP system. The organization of maintenance intervals and spare parts management is automated. Operating times, plant utilization, energy data, etc. are thus completely transparent and support management in operational and strategic decision-making. This part of the solution presented here is the task of Syntax Systems.
Matthias Wieland is Sales Head Europe and Global Partner Management at Bosch Digital Twin Industries. © Bosch
Mr. Wieland, what is special about the Bosch IIoT Starter Kit?
Matthias Wieland: The 'aha effect' or the 'aha experience'. The starter kit is a plug and play kit that demonstrates to customers the 'simplicity' of digitalization and the first steps of digital transformation. To use the kit for a test setup in the laboratory or at the desk, for example, the user only needs to provide network access and a power supply. When the power supply is switched on, the system initializes and configures itself automatically. The process data is then transferred to the backend for further processing.
As the kit is completely flexible and freely scalable in every respect, it is also possible to test the set-up directly in an application. To do this, however, it is necessary to clarify the task with us in advance. Once a project plan has been drawn up, the required sensors are defined. The customer installs the set-up according to installation instructions, but we can also take care of this as a work package. As on the desktop, the automated initialization and configuration with subsequent transfer of the machine and process data takes place after switch-on. The teach-in phase starts based on ML and AI, after which the kit is put into operation.
SSV
AI-based Continuous Monitoring
Each connected module now includes integrated AI functions: while this is standard in today’s smartphones, it remains rare in automation. Yet, such AI could serve as a foundation to detect communication issues caused by cyberattacks in real time.
Festo at the SPS 2024
Minimizing Downtime with AI
Machines not only produce goods but also generate large amounts of data. This data can be transformed into actionable insights through AI, revealing specific optimization opportunities for companies. Sebastian Werler, Head of Product Management...
