Fraunhofer IPA / Sick
Intelligent sensor detects leaks
To simplify the search for leaks in compressed air systems, a researcher from Fraunhofer IPA is working with Sick to develop an additional leakage service for an intelligent flow sensor. Self-learning algorithms evaluate the measurement data.
A researcher from Fraunhofer IPA is working with Sick to develop an additional leakage service for this flow sensor.
© Sick
Around 60,000 compressed air systems are in operation in Germany, which together consume 16.6 terawatt hours every year - 7% of the total electricity consumption of domestic industry. However, up to 30 % of the energy used escapes unused through tiny leaks. Detecting these holes, kinks or leaking connectors has so far involved a great deal of effort.
"The products and methods available on the market for detecting leaks are not worthwhile for many users," says Christian Dierolf from the Industrial Energy Systems department at the Fraunhofer Institute for Manufacturing Engineering and Automation IPA. "To use them, you either have to repeatedly detect leaks with an ultrasonic device or retrofit new valves for individual monitoring of the pneumatic actuators." Many companies are therefore forced to live with waste.
Researcher Dierolf has tackled this problem in close cooperation with Sick and is developing an additional leakage service for an intelligent flow sensor from Sick. This service continuously records pressure, temperature and flow rate and generates seamless curves. These curves are evaluated by a self-learning algorithm. The trick here? "Clustering: leaks are reflected in characteristic curves. The algorithm recognizes these and sounds the alarm," explains Dierolf.
Implementation should be simple: The sensor, which Fraunhofer IPA and Sick are jointly developing from concept to series production, does not need to be connected to the machine control of the compressed air system or to an industrial PC. Instead, the flow sensor itself has a small display and other interfaces such as MQTT and OPC-UA, which allow the user to be notified automatically. The user can also access the sensor via a web interface. The algorithm will also teach itself. With this so-called unsupervised machine learning, a human only has to check at the end whether the algorithm has drawn the right conclusions from the available information.
"For us, the results from the joint development project are reason enough to make clustering available to our customers as an intelligent service as standard in future generations of flow sensors," says Thomas Weber, Head of Development in the Industrial Instrumentation division at Sick.
So far, the additional leakage service is a prototype. A compressed air demonstrator system was recently built at Sick's headquarters in Waldkirch and delivered to the Fraunhofer IPA in Stuttgart. It contains the sensor prototype, which is now being tested and further developed.
Fraunhofer IPA
The digital value stream analysis
A research team from Fraunhofer IPA is digitizing value stream analysis together with the Stuttgart-based software provider Ifakt. This should enable this optimization method to be carried out in the future with significantly less effort and almost...
Fraunhofer IPMS
Sensors learn to think
In the Fraunhofer lighthouse project NeurOSmart, the Fraunhofer Institute for Photonic Microsystems IPMS and four other institutes (ISIT, IMS, IWU, IAIS) are researching particularly energy-efficient and intelligent sensors for the next generation...
Fraunhofer IPA
Improved safety for service robots
In the S³ research project, researchers at Fraunhofer IPA and their project partners have developed safety technologies and recognition algorithms for service robots. They were tested on the Care-O-bot 4 service robot in a nursing home application.
Sick
Paving the way for digitization
'We Create Digital Transformation' was Sick's trade fair motto to present intelligent sensors as pioneers of digitalization as well as digital services and software solutions based on their data.
