LiDAR sensors
Quelle: Pepperl+Fuchs | Inka Krischke,
Detect objects in 3D
Pepperl+Fuchs presents switching and measuring LiDAR sensors based on 'Pulse Ranging Technology (PRT)': One of these is the R2300 3D multi-layer scanner (image) for collision avoidance, navigation support and object detection.
© Pepperl+Fuchs
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
