Pepperl+Fuchs
Yvonne Junginger,
360° inclination measurement of the horizontal position
The IMU F99 inclination sensor from Pepperl+Fuchs provides stable inclination values for dynamic applications such as construction, agricultural and forestry machinery, wind turbines and AGVs.
© Pepperl+Fuchs
According to Pepperl+Fuchs, external disturbance variables (e.g. potholes) are filtered out without delay. Software adjustment is carried out via CAN bus. The dynamic inclination sensor measures both rotation rates and accelerations in all three spatial directions and then merges these into an angular value using an intelligent algorithm. This enables a stable angle output.
As the different types of machine movement nevertheless require individually adapted fusion of the rotation rate and acceleration, these can be set so that position measurements of a wheel loader, a bulldozer, a crane, etc. are possible with one device. In addition, the inclination sensor also provides the rotation and acceleration rates in three axes in parallel to the angle output.
Pepperl+Fuchs
The digitalization of Ex zones
True predictive maintenance is only possible in a fully networked production environment - including Ex zones. However, there is often a digitalization gap in hazardous areas. Intrinsically safe mobile devices promise a remedy here.
Hanover Fair
HANNOVER MESSE DAILY Day 4
The top news from the fourth issue: Robert Habeck at the trade fair tour +++ Technological AI highlights from Beckhoff +++ Radar sensor technology in focus at Pepperl+Fuchs +++ ASi-5 counter module as an active distributor from Bihl+Wiedemann +++...
