Ruhr University Bochum
Securely transmit new passwords
Forgot your password? No problem: You can either receive a new one by e-mail or answer a security question and receive a password directly. Both methods offer vulnerabilities for hackers. Now there is an alternative.
Conventional methods for transmitting a new password have weak points, as Prof. Dr. Markus Dürmuth, head of the Mobile Security working group at Ruhr-Universität Bochum (RUB), knows: "Emails are transmitted in plain text and can easily be read. The correct answers to security questions, on the other hand, can often be guessed with a bit of luck and research."
Together with a colleague from the University of California, Berkeley, and a colleague from INRIA (Institut national de recherche en informatique et en automatique), Grenoble, Dürmuth has developed an alternative to the methods described above. They use so-called 'Mooney' images. These are black and white images that have been processed with a special filter.
When you see a Mooney image, you don't recognize anything at first. Only when you see the original image do you recognize the motif on the Mooney - an effect that lasts for a long time. This is known as 'priming' or 'imprinting' on the image.
Dürmuth uses the mechanism as follows: instead of having to think of a security question and the corresponding answer just in case, the user is shown ten Mooneys and the corresponding original images during the priming phase. If they then forget their password at some point, they are shown 20 Mooneys and asked to state what they have recognized. "The real account holder will recognize the ten Mooneys on which he was primed," says Dürmuth. "But they won't be able to identify the other ten. He is then directly assigned a new password." A hacker would give himself away by either not recognizing any Mooneys at all, or by recognizing Mooneys that are unknown to the actual user.
