Safety switch
Quelle: Euchner | Inka Krischke,
Safety for smaller systems
With the CES-C07 safety switch and the ESM-CB safety module, Euchner has a duo in its portfolio that, according to the manufacturer, opens up new freedom in the design of safety solutions for smaller systems.
© Euchner
Together, they are able to communicate at Industry 4.0 level. They achieve requirements up to safety function category 4 and performance level e (PLe). The safety switch provides process-relevant parameters in real time, for example to obtain information for preventive maintenance. For example, the sensors measure relevant environmental parameters and signal in good time whether a system failure is imminent. The system also reports tampering attempts. In combination with the safety module, this information is automatically queried by each switch in the chain and made available to the control system via IO-Link.
Euchner
Focus on small flaps and doors
The safety systems integrated into systems or machines must be designed in such a way that they do not interrupt production processes and keep system productivity at a high level. What can transponder-coded guard locking do?
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
