Sigmatek
Processing speed quadrupled
S-Dias Safety from Sigmatek complies with the SIL 3, PL e safety standards. According to the supplier, the SCP 211 safety CPU now ensures even greater performance.
The SCP 211 safety CPU from Sigmatek
© Sigmatek
According to Sigmatek, the safety CPU has four times the processing speed of its little sister 'SCP 111', more memory for application programs (1 Mbyte flash, 500 Kbyte SRAM) and retentive memory for parameter lists and variables. The 25 mm wide top-hat rail module provides 1.6 A total current to supply the S-Dias safety modules. Functions such as the creation of arrays, marker variables, constants in list form and reloadable parameter lists simplify the creation and handling of safety applications. The safety-relevant application is configured in the graphical editor of the Lasal SafetyDesigner. The library contains over 50 safety function blocks based on PLCopen, such as Emergency Stop, Two Hand Control and Guard Locking. New safety function blocks for interpolation, conversion of data units and array processing have been added.
Sigmatek
Visualize movement
Aluminum windows are precision components whose accuracy of fit contributes to the energy efficiency of a building. Highly automated production with a sophisticated drive and operating concept helps to maintain high quality standards.
