Goudsmit Magnetics
Vertical access to sheets
The magnetic gripper from Goudsmit Magnetics is used to automatically pick up, place or position steel objects or other ferromagnetic objects.
© Goudsmit Magnetics
Furthermore, other ferromagnetic objects - such as picking up sheets from presses, destacking products from boxes (bin picking), assembling steel parts or handling punched steel parts, blanks and perforated steel sheets in robot applications.
The magnetic gripper is equipped with strong, permanent neodymium magnets and can be used in grippers on robot arms. The handling magnets can be switched on and off using compressed air; they have a threaded hole for attachment to the robot arm, if necessary in conjunction with a spring plunger.
Posital
Two become one
The current situation in robotics: Until now, two single-turn encoders working in parallel - plus gears for synchronization - have been required for speed monitoring and position control per robot arm. A new kit encoder from Posital can now do this...
IoT Hotspot
Focus on cloud and edge computing
The Eclipse Foundation, currently the largest open source organization in Europe, wants to promote global industry collaboration on open source projects in strategic technologies. Mike Milinkovich, Executive Director of the Eclipse Foundation,...
