Igus
Room gantry robot in low-cost version
Igus expands its low-cost automation range with a drylin XXL room gantry robot.
© Igus
The pick-and-place linear robot for palletizing, sorting, labelling and quality inspection tasks can be assembled and programmed according to the do-it-yourself principle, without the help of a system integrator. The purchaser receives the room portal as a DIY kit. The components are two toothed belt axes and a rack and pinion cantilever axis with stepper motors and an operating range of 2,000 mm x 2,000 mm x 1,500 mm; the maximum length is up to 6,000 mm x 6,000 mm x 1,500 mm. The package also includes a control cabinet, cables and energy chains as well as the 'igus Robot Control (iRC)' control software. If additional components such as camera systems or grippers are required, users can find these on the robotics marketplace 'RBTX'. The portal is particularly suitable for palletizing applications up to 10 kg.
Igus
Low-cost robotics in use
How can a 100% inspection at the end of a production line be automated cost-effectively? A manufacturer of chargers for electric vehicles relies on a 5-axis articulated arm robot that takes over the test cycle and uses various test equipment.
Igus
Energy and data combined
Igus has expanded its range of hybrid cables with a cable especially for SEW motors with the 'Movilink DDI' interface. This gives users access to a cable specially developed for use with energy chains.
Igus
Fire protection rethought
New at Igus is UL certification for halogen-free TPE cables. Rainer Rössel, authorized signatory and head of the 'Chainflex' cables business unit, explains why this is a major issue.
