Rollon
Cartesian robot for loads up to 10 kg
The Cartesian robot 'H-Bot' from Rollon offers a design with a single belt concept and double motor on the X-axis, which, according to the manufacturer, enables coordinated and precise movements in a compact design.
© Rollon
The Rollon robot consists of two X-axes and a Y-axis with aluminum profiles. It is driven by two fixed motors on the X-axis with a single belt that is driven by pulleys and is easy to tension. By dispensing with a motor on the Y-axis, the moving masses are significantly reduced, which reduces vibrations and enables high dynamics. A drive shaft between the two X-axes is not required. The linear axes with toothed belt drive and recirculating ball bearing guides achieve a maximum stroke of 2500 mm on the X-axis and 1500 mm on the Y-axis. Speeds of up to 5 m/s and accelerations of up to 50 m/s² with a repeat accuracy of ±0.1 mm are possible in both axis directions. Mounting is horizontal and allows integration of the Z-axis.
Physical AI
Humanoid Robotics at BMW in Spartanburg
 "Physical AI" combines digital AI with real machines and robots. This allows intelligent systems, such as humanoid robots, to be integrated into real-world production processes. Following the successful deployment of the Figure 02 humanoid robot at...
