Advertorial
Faulhaber | Tiffany Dinges,
Micro motors as the driving force behind intralogistics
Suitable transport structures in intralogistics are a prerequisite in all industries in order to withstand competitive pressure in the future. The basis for this is comprehensive automation, which would be inconceivable without an armada of powerful micromotors.
© Faulhaber
These often have to release considerable forces in very confined spaces, work reliably even in continuous or stop-and-go operation and often also position with high precision. Drive systems from FAULHABER have proven their efficiency in many applications, from sorting and transportation to a wide variety of robotic solutions.
Transporting and sorting
Intralogistics is inconceivable without an armada of powerful micromotors. The drives have to release considerable forces in often very cramped conditions, always work reliably even in continuous operation and often also position with high precision.
© Faulhaber
If products are transported on conveyor belts or roller conveyors, they can be separated via diverters, flaps or pushers and transported to the desired processing route. It is not only in large warehouses, where thousands of parcels are transported per hour, that speed is of the essence when it comes to automatic sorting. The switches must be set to the correct position with split-second precision. For this task, graphite commutated DC-micromotors are often used in conjunction with gearboxes designed for this purpose. Their commutation system is very robust and is particularly suitable for dynamic high-performance applications with fast start/stop operation, as required for automatic sorting.
Autonomous logistics robots
The TORU logistics robot combines autonomous driving with handling robotics.
© Faulhaber
Autonomously driving and independently acting logistics robots are a crucial building block for "Intralogistics 4.0". They are used for storage as well as retrieval and shipping preparation. A typical setup consisting of a lifting column and gripper on an autonomous logistics robot contains, for example, brushless DC servomotors with integrated motion controllers and planetary gears as the drive unit. When used in the lifting column, this combination ensures precise positioning during storage or retrieval in continuous operation with constant load changes. The complete drive unit only weighs around 300 g. This means that there is no need for a counterweight, even when the gripper is fully extended. With a diameter of just 32 mm and a length of 85.4 mm, the brushless DC servomotors are also very compact. This makes it possible to design the gripper to be very flat so that it can also pick up packages that are stored just above the floor. Expensive storage space can thus be optimally utilized.
Flexible through production
Automated guided vehicles (AGVs) are the means of choice for ensuring flexible transportation in the production process. Drive technology from FAULHABER plays an important role here: Brushless DC servomotors, for example, are suitable for driving the wheels; the motor power can be transmitted to the wheels via planetary gearheads and drive belts (Fig. 3). Encoders from the IE3-1024 series are attached directly to the servomotors for precise position detection. The magnetic incremental encoders, which are available with different resolutions, have an index channel for referencing one revolution of the drive shaft and a standardized electronic encoder interface. Resolution, direction of rotation, index width and index position can be flexibly adapted to the application. A motion controller controls the servomotors and communicates with the control system. The microdrives are also used in mobile robot platforms that move completely autonomously in industrial halls without a pre-installed control system. Here, they can score points in the wheel modules primarily due to their high power density. There is hardly an area of intralogistics in which the small FAULHABER drive systems are not represented.
Visit FAULHABER at automatica 2023: Hall A5, Stand 506
Schaeffler
At its meeting on September 26, Schaeffler's Supervisory Board made two appointments to the Executive Board. There is also another change in the Executive Board. As a result, the Executive Board will consist of nine members from October 1, 2024...
TQ-Group
Expansion of the RoboDrive business unit
TQ is expanding its RoboDrive division. The focus is on series production and the development of complete drive systems. The aim is to leverage potential in the growth markets of humanoid and collaborative robotics as well as industrial automation.
