Dr. Fritz Faulhaber
Motion controller for small and micro drives
Faulhaber is launching the housing-less 'MC3603', a motion controller whose compact dimensions make it particularly suitable for integration in device construction and medical technology applications.
© Faulhaber
With 36 V and 3 A (peak current 9 A), it covers the medium power range up to approx. 100 W and is suitable for 'normal' DC motors with encoders, brushless drives and linear motors. The I/O scope and encoder interfaces correspond to those of the entire device family. USB, RS232, CANopen and Ethercat are available for communication. The motion controller already contains firmware version "M". The latest update (version 6.9) of the 'Faulhaber Motion Manager' is available for system setup. All Motion Controllers in the family comply with the current EMC regulations.
Lean technology
Easy to implement
Nabtesco
The gearbox makes the robot
How precise, strong and fast a robot is depends on the performance of the gearboxes used. In the white paper, you can find out what is important in the design and how your robot can also benefit from the properties of Nabtesco gearboxes.
