Faulhaber
Turnkey linear actuators
With the 'Linear Actuator Family L', Faulhaber provides a turnkey solution for a wide range of applications.
© Faulhaber
The smaller versions 06L/08L/10L are particularly suitable for applications in the fields of medicine, laboratory automation, optics and photonics or aerospace. The larger versions 22L/32L use the latest GPT gear technology and are designed for applications in industrial automation, optics and photonics. The linear actuators in Faulhaber 's L product family can be combined with a wide range of DC motors, 4-pole and 2-pole brushless motors or stepper motors. The family was developed for high performance with compact dimensions. Numerous, evenly distributed reduction ratios are available so that the most suitable configuration for different force or speed operating points can be selected depending on the application. Different spindle sizes and types are also available. The robustly built devices offer various options relating to the coupling, the spindle or both, such as spindle type and length, nut type and length, environmental conditions such as a particular temperature range or special environmental conditions such as vacuum, different motor cable or terminal orientation when integrating the device combination into the application.
Lean technology
Easy to implement
Nabtesco
The gearbox makes the robot
How precise, strong and fast a robot is depends on the performance of the gearboxes used. In the white paper, you can find out what is important in the design and how your robot can also benefit from the properties of Nabtesco gearboxes.
