Kassow Robots
Cobots with a reach of 1.80 m
Kassow Robots has added two more models to its product portfolio: the KR1805 robot arm with a reach of 1.80 m opens up new areas of application for industrial customers
© Kassow Robots
Thanks to the 7th axis, which can reach around corners, a single cobot can handle all tasks relating to palletizing and labeling Euro pallets, for example. The Cobot KR1410, on the other hand, offers a reach of 1.40 m and a load capacity of 10 kg. On the four Cobot models that now belong to the product family, the company installs three connections with various I/Os and power supply signals as standard. Two of the connections are for digital or analog inputs/outputs. The third connection enables data/Ethernet communication, which is connected directly to the controller. This allows industrial customers to intelligently connect camera solutions or Modbus TCP directly to the robot at the end-of-arm tool, for example - the cable therefore does not have to be routed on the outside of the robot arm.
OnRobot
Grasp like a gecko
With the Single Pad Gecko gripper, OnRobot is launching a compact version of the 'Gecko' gripper, which is particularly space-saving and lightweight. It is designed for three different payloads.
Exner
Robot programs itself
Robot welding processes have been unprofitable in steel construction to date. This has changed with a solution in which the robot programs itself and then welds each component immediately.
AMO
Operating cobots safely
AMO's measuring devices measure position values with deviations of less than 1 µm per signal period, which enables precise positioning of robot axes and thus the safe operation of cobots in close proximity to human workers.
