OnRobot
Grasp like a gecko
With the Single Pad Gecko gripper, OnRobot is launching a compact version of the 'Gecko' gripper, which is particularly space-saving and lightweight. It is designed for three different payloads.
© OnRobot
Its special holding technology is based on the way gecko feet work and, unlike conventional vacuum grippers, also allows automated handling of perforated workpieces such as drilled circuit boards. The 'Single Pad Gecko' is available in the versions SP1, SP3 and SP5, which are named after their respective load capacity in kilograms.
The gripping technology is modeled on the way geckos climb. It works with millions of microscopic hairs that are located on the gripping surfaces. When pressed onto a flat object, they generate adhesion through van der Waals forces. The gripper is particularly suitable for handling flat objects with shiny surfaces such as tiles or displays. It can be attached to any standard collaborative robot arm using OnRobot's One-System-Solution.
OnRobot
Parallel gripper for the clean room
With the 2FG7, OnRobot presents a gripper that users can also use in cleanrooms without any problems: The electric parallel gripper is IP67-certified and is particularly suitable for the automation of small series or a large number of variants.
ABB
'Second life' for used robots
Instead of scrapping inactive or older robots and leaving them unused in the production hall, existing customers can sell them to ABB via a buy-back service. The robots are reconditioned there.
AMO
Operating cobots safely
AMO's measuring devices measure position values with deviations of less than 1 µm per signal period, which enables precise positioning of robot axes and thus the safe operation of cobots in close proximity to human workers.
VMT
Dynamic visual guidance for 6-axis robots
As part of the production ramp-up for the Audi model derivatives of the A3 successor at the Ingolstadt plant, an automated system for the application of primary seals in vehicle doors was put into operation together with the image processing system...
