Drive programming
Without external control
With the drive-based ‚Sequential Motion Control SMC‘ function, users can reduce the programming and commissioning effort by up to 90 % compared to classic PLC automation, according to the supplier Rexroth.
© Bosch Rexroth
© Bosch Rexroth
With ‚SMC‘, users program single- and multi-axis applications directly into the intelligent ‚Indradrive‘ drives without external control. The individual commands take over complete motion sequences and are arranged one after the other. They cover the majority of typical functions such as independent positioning axes, axis and master axis couplings, synchronous operation as well as cam disk applications and sequential movements. The range of applications extends from handling systems and test benches to flying cutting devices. Since Rexroth delivers the drives preconfigured, users are relieved of time-consuming routine tasks such as operating mode definition, diagnostics and error handling. The new function includes manual operation, a parameterization mode and automatic operation for program execution.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
drive controller
Modular interface concept
The flexible SD6 belongs to Stöber‘s family of stand-alone and bayed drive controllers for multi-axis applications. The single-axis controller with a rated output current of up to 85 A controls linear and rotary synchronous servomotors as well as...
