Controller
Maintenance-free operation
SEW-Eurodrive is expanding its control technology family with the UHX65A controller in the 'progressive' performance class.
© SEW-Eurodrive
It is based on the 'CPC' modular system (Cyber Physical Controller) with numerous hardware components such as scalable CPU modules, fieldbus options (multi-protocol capability) and WLAN variants. The passive cooling and RTC function (real-time clock) without battery replacement enable maintenance-free operation. In addition to the 'Movikit' software modules, the modular software system also includes solutions for safety, axis/controller exchange functions and configured code generation. The implementation of a software layer model based on hypervisor technology enables the interaction between real-time control on the one hand and higher-level software functions such as visualization, condition monitoring, data mining, engineering software, diagnostics, IT communication stacks or intelligent sensors on the other hand. A CFast memory card, which contains all important data such as firmware, application, axis data records and application data, simplifies device replacement. The processor capacity of the progressive controller can in future be scaled, ordered and used from one to four processor cores for the PLC part. In this way, the user can select and adapt the performance for his application in a customized manner.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
drive controller
Modular interface concept
The flexible SD6 belongs to Stöber‘s family of stand-alone and bayed drive controllers for multi-axis applications. The single-axis controller with a rated output current of up to 85 A controls linear and rotary synchronous servomotors as well as...
