Analog modules
Channels individually parameterizable
Wago is expanding the I/O system 750 by adding the module 750-471 with four electrically isolated analog inputs.
The galvanic isolation of signal inputs is particularly important in areas where interference can occur, for example due to potential differences - for example in marine and offshore applications. The resolution of the inputs of the analog module is 16 bits. The channels can be parameterized individually, either as current inputs of 0 to 20 mA, 4 to 20 mA, 3.6 to 21 mA (NE43) or ±20 mA, or as voltage inputs with the ranges 0 to 10 V, ±10 V and up to the mV range of ±200 mV. The user can individually parameterize the modules according to requirements and only needs one module to be able to record almost all analog encoders.
