Remote maintenance
Quelle: Wachendorff Prozesstechnik | Inka Krischke,
Various controls can be upgraded
The established Ewon & Talk2M remote maintenance system provides convenient access to machines and systems equipped with Siemens controllers.
© Wachendorff Process Technology
The Ewon Flexy series routers can do much more: they enable the recording, visualization, alerting and pre-processing of data at the edge. The already implemented cloud connectivity for Microsoft Azure and Amazon Web Services is the basis for Industry 4.0 and IIoT applications. With the connector for Siemens Mindsphere, the Ewon Flexy router also offers plant operators in particular a very efficient way to easily connect their plants to the Siemens Mindsphere platform. Existing machines and systems with S7-200/300/400 controllers can be upgraded for IIoT applications with the many retrofit options of the Ewon Flexy router. The controllers are connected to Mindsphere using the MPI/Profibus and/or ISO-TCP protocols. Controllers from other providers such as Schneider Electric, Allen Bradley, Beckhoff, Mitsubishi, Hitachi and Omron can also be integrated quickly and easily.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
