B&R
Inka Krischke | Tiffany Dinges,
Configuring instead of programming
With a ready-made software solution from B&R, machine builders can now implement pick & place applications much more easily, according to the supplier.
© B&R
The system not only controls the robot itself, but also coordinates with other axes, conveyor belts or intelligent track systems. mapp Pick&Place gives the user maximum freedom in designing the process. Any number of delta, articulated arm and scara robots can be used. The software also automatically optimizes the process according to the application manufacturer's requirements.
Options include, for example, the shortest possible picking time, first in - first out or energy-optimized movement profiles.
The tool is based on the 'mapp Technology' modular software system and is therefore automatically connected to all other 'mapp' software components. Coordination with other axes, the B&R vision system or the web-based 'mapp View' visualization can therefore be set up with just a few clicks. A large part of the manual programming work is eliminated.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
B&R
The hovering shuttles!
At SPS 2018, Beckhoff presented a transport system based on magnetically levitating shuttles. B&R is now following suit and wants to set the pace with this technology. Markus Sandhöfner, head of B&R Germany, explains the details of the...
B&R
More space in the switch cabinet
The Acopos P3 servo amplifier from B&R is also available with a through-hole cooler or cold plate cooling. According to the manufacturer, these new cooling variants allow up to 60% of the heat loss to be dissipated into the ambient air outside...
B&R at SPS Connect
From a single mold!
Robotics and machine automation from a single source: B&R is approaching the market with this philosophy. But what advantages does the user gain from such an overall concept? Sebastian Brandstetter, Product Manager Integrated Robotics at...
