Routers
Case it IP40 or IP65
NB800 EcoRouter from NetModule aims at applications in and around Industry 4.0 and IoT where robust connectivity and dependability are essentials. The focus is on simple integration and remote configuration/management.
© NetModule
Device features include a 3G/4G cellular/Ethernet gateway, plus a high-performance two-channel VPN protocol suite. The router is housed in an IP40 or IP65 graded case. It comes as a UMTS and LTE+WLAN version as well as custom OEM, for instance as a tag finder to track freight. Specially for OEM versions, hardware shields mean extra agility because these small and plugged add-on modules can be matched to the particular use. Currently there are shields with dual CAN, with serial interfaces and digital I/Os; upcoming are GNSS and LoRa.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
