Panel PCs
Quelle: Extra Computer | Lukas Dehling,
WLAN-capable despite sealed housing
The Panel PC 15EF0ag from Extra Computer has a robust die-cast aluminum housing with protection class IP65 and Ikotec screw connection.
© Extra Computer
Despite the sealed housing, the device is WLAN-capable: an integrated WLAN card allows the Panel PC to be wirelessly integrated into the wireless network. This is achieved using special external WLAN antennas that are also IP65-protected. The TFT display with a screen diagonal of 15 inches is designed to ensure comfortable readability and a good overview. The shatterproof dual-touch cover can also be operated with gloves. The PC also has variable connection options and can be wall-mounted via VESPA 75 or 100. The 15EF0ag is based on the Fujitsu D3313-S3 mainboard and can be used at temperatures from 0 °C to +50 °C.
Friedhelm Loh Group
Managing Board expanded
The Friedhelm Loh Group is aligning its group of companies for the future and is expanding its Executive Board to include Prof. Dr. Niko Mohr. He joins owner and CEO Prof. Dr. Friedhelm Loh and CFO Ralph Lindackers on the Executive Board.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
