Fischer Electronics
Housing for Raspberry Pi 5
Fischer Elektronik offers the right housing for the Raspberry Pi 5. The housing consists of an upper and lower shell made of punched and bent 1.5 mm thick aluminum sheet.
© Fischer Electronics
The respective circuit board is attached to four steel spacer bushes in the bottom shell using M2.5 pan-head screws. Quick access to the inside of the enclosure is made possible by fastening the top shell to the bottom shell with just one screw and the tongue and groove system on the front of the enclosure. The ventilation openings in the top and bottom shells ensure good heat dissipation. If required, Fischer Elektronik offers heat sinks in all sizes and designs for the Raspberry Pi housing. Especially for the Raspberry Pi 5, there is the Active Cooler made of an aluminum heat sink with a temperature-controlled fan. If required, the RSP enclosures can be fitted with non-slip, transparent device feet with adhesive on one side. If wall mounting is required, mounting brackets can be selected that are also suitable for the standard VESA MIS-D 75× 75 monitor mount.
Friedhelm Loh Group
Managing Board expanded
The Friedhelm Loh Group is aligning its group of companies for the future and is expanding its Executive Board to include Prof. Dr. Niko Mohr. He joins owner and CEO Prof. Dr. Friedhelm Loh and CFO Ralph Lindackers on the Executive Board.
