Siemens
Andrea Gillhuber,
First control cabinet made of green steel
The Siemens subsidiary Alpha Verteilertechnik claims to offer the first industrial control cabinet made entirely of green steel.
© Siemens
The 'Sivacon 8MF1' control cabinet series from Siemens subsidiary Alpha Verteilertechnik is made from 100% scrap from European suppliers with wind power. With this step, Siemens is pursuing its sustainability goals in the areas of decarbonization and resource efficiency, which are defined in the DEGREE framework.
In the manufacturing process for the control cabinets,CO2 emissions are 70% lower than for conventional steel, which is usually produced in a blast furnace using iron ore and coal. This reduction translates into a saving of 308 kg ofCO2 per cabinet unit. Steel production is currently responsible for 8% of global emissions. As demand for steel continues to rise, it is crucial to decarbonize production, according to the Group.
The new variant has the same technical characteristics and functionalities as cabinets made from conventional steel. This enables larger industrial customers to reduce theirCO2 emissions and get closer to their sustainability goals.
The DEGREE framework
The DEGREE framework is part of Siemens' long-term strategy to take a leading role in sustainable development and actively address both environmental and social challenges. It is intended to ensure that the company is not only economically successful, but also makes a positive contribution to the environment and society. DEGREE is an acronym for six pillars:
  • Decarbonization: Siemens aims to reduceCO2 emissions and become carbon neutral by 2030.
  • Ethics : The company values ethical behavior in all business areas and aims to set high standards in the areas of compliance and transparency.
  • Governance stands for responsible and transparent corporate management aimed at ensuring sustainability and long-term value creation.
  • Resource Efficiency: The focus is on the efficient use of resources and reducing the ecological footprint in order to conserve natural resources.
  • Equity: The Group aims to promote diversity, equality and inclusion within the company and in society.
  • Employability: The development of employees' skills and competencies should be promoted in order to ensure the employability and well-being of the workforce.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
Siemens
For personal use
Siemens operates vertical farming for its own use at its site in Frankfurt. Siemens technology is used here. What works here on a small scale is also a future field for agriculture in general.
In focus: Agriculture
The e-paper of issue 05/2024
Strategies for the future are one of the topics covered in the current issue of Computer&Automation. Read about the reforms that associations are demanding from politicians, the opportunities offered by technologies such as ChatGPT and SPE and...
