Grossenbacher systems at the SPS 2022
Yvonne Junginger,
Smart Panels with Soft PLC under Linux
Grossenbacher Systeme presents a new generation of compact operating panels with soft PLC under Linux.
© Grossenbacher
The Grossenbacher operating panels are based on ARM hardware and contain the Codesys soft PLC including the Codesys Control Runtime Toolkit. As standard, i.MX 8M Mini processors from NXP with four cores and a clock frequency of 1.8 GHz are used on SoM modules. Other i.MX 8 processors are available on request. In terms of memory capacity, 2 to 4 Gbyte RAM and 8 to 128 Gbyte mass storage are available, the latter can be optionally expanded using microSD cards.
The capacitive touch displays are available in seven-inch and 18.5-inch sizes. Gestures such as swiping, zooming etc. are supported. Various options are available in terms of visualization, including Qt-based Visu, EPAM from the manufacturer or web-based visualizations such as Codesys WebVisu. The Linux OS also makes it possible to use other applications on the smart panel. Other communication standards such as OPC UA, MQTT and others can also be implemented.
Ifak
It's more efficient! - Part 2
How can man and machine cooperate better in production? With the ITEA project Optimum, a research association has now formulated and implemented the necessary development goals. Article 2.
Ifak
How can man and machine cooperate better in production? With the ITEA project Optimum, a research association has now formulated and implemented the necessary development goals. - Article 1 of 2.
Pepperl+Fuchs
The digitalization of Ex zones
True predictive maintenance is only possible in a fully networked production environment - including Ex zones. However, there is often a digitalization gap in hazardous areas. Intrinsically safe mobile devices promise a remedy here.
