Portable display device
Quelle: Althen,
Saves measurement data, displays diagrams
One of Althen's highlights is the TD-01 Portable. The mobile, digital display device can be connected to strain gauge-based sensors and display input signals from sensors as display values, graphics or functions on a color TFT LCD display.
© Althen
It has a high-speed A/D converter, indicator recording, interruption control and support for TEDS (automatic calibration). With the free 'TdDataPicker' software, the measurement data can be recorded in CSV format and saved indicator values and diagram data can be displayed. The device is used for force measurement during resistance welding and for press connections or pedal force measurement.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
