Wachendorff Process Technology
No additional PLC hardware required
The HMI of the cMT series from Wachendorff Prozesstechnik can be easily upgraded to a high-performance operating device with integrated Codesys V3 control using a Codesys activation card in conjunction with a license sticker.
No hardware modification is required for this. The HMIs are based on an architecture in which a dual-core CPU runs two independent operating systems. According to the provider, the multi-core processor enables the HMI to implement data visualization with an operable user interface and simultaneously operate the control logic. This means that the entire performance is available for the respective processes.
HMI models with 7-inch, 9.7-inch and 15-inch screen diagonals are available.
