Wachendorff Process Technology
Andrea Gillhuber,
New IPC generation in stainless steel
Wachendorff's new generation of IPCs focuses on stainless steel and computing power.
© Wachendorff Process Technology
The stainless steel IPCs in the ViTAM series from Wachendorff are designed for demanding conditions and the new ViTAM-9A generation comes with a waterproof stainless steel housing. The 6th and 7th generation Intel Core i processors and up to 16 GB DDR4 RAM memory provide the necessary performance.
Other features include expansion options such as HDMI and CAN interfaces as well as optical bonding, which, in conjunction with a high-brightness LCD, significantly improves readability.
The IPC complies with protection classes IP66 and IP69K.
Wachendorff
Alcohol-free with a concept
So that people who do not drink alcohol can also enjoy wine specialties, alcohol-free wine has been produced at Boosenburg Castle using the 'Carl Jung method' since 1907. An automatic wine filter system including a CIP system is indispensable.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
