Actemium
Dennis Trosdorff | Andrea Gillhuber,
Monitoring for more sustainability
Beverage bottling plants are highly complex systems. In order to optimize planning and process reliability, Krombacher relies on a modern monitoring system for twelve of its bottling plants. At the same time, the brewery is increasing the potential for greater sustainability.
© Actemium
Germany is a beer nation. This is demonstrated on the one hand by the per capita consumption of around 100 liters per year, and on the other by the Purity Law, which dates back to 1516 and still applies today. At the same time, cherished traditions and technical change go hand in hand, as digitalization has long since found its way into beverage production and bottling in particular. For example, the long-established company Krombacher has brought the monitoring of its twelve bottling lines up to date with the help of industrial service provider Actemium. The system gives the beverage producer full transparency of its filling lines, the associated machines and energy management, among other things. The results are increased planning and process reliability as well as an improved cost and energy balance.
The Krombacher brewery produces more than 5.7 million hectoliters at the site of the same name in the German state of North Rhine-Westphalia - from different types of beer to non-alcoholic soft drinks. The company turned to Actemium with the requirement to be able to obtain further data from the monitoring of the bottling lines and thus more comprehensive production reports, more precise annual analyses and thus also a better energy and environmental balance. In order to successfully introduce the new monitoring system, the industrial service provider had to integrate 250 control systems (PLCs) from eleven existing bottling lines, another new bottling line set up by Krombacher and connected auxiliary systems.
From inspection to planning
The new IT infrastructure at Krombacher as a circuit diagram.
© Actemium
Before a tailor-made solution could be developed for the new system landscape, Actemium and Krombacher first held joint workshops to clarify the exact requirements and then inspect the existing architecture. For example, the old system used various software solutions to record operating data from the field level and quality data and store it in an SQL database. The latter was recorded manually and entered into Excel for local reporting. There was also software for displaying trend reversals and another for visualization as a graphical interface. The reported key figures were then sent to the data warehouse and the SAP system.
In addition to the various software solutions running alongside each other, the difficulty lay in the manual recording of quality data, which led to a higher susceptibility to errors. At the same time, SAP postings via SQL place high demands on the system to reliably deliver the correct figures. In the case of Krombacher, the old system was also discontinued and had to be replaced. Added to this is the possibility of real-time analysis of consumption quantities directly in the SCADA, which is very helpful in the search for optimization potential and quick troubleshooting. The old system therefore offered potential for a new system to increase efficiency through valid fault data and reduce resource requirements at various points.
The new system landscape therefore had to be able to record and visualize the entire production process - from beverage production and filling to energy management. To achieve this, different systems as well as the entire bottling lines had to be integrated and a comprehensive reporting system had to be possible. On the one hand, the challenge was to integrate the existing 250 or so PLC control systems at the start of the project in order to record and process 120,000 messages, 40,000 measured values and 20,000 counters. On the other hand, it had to be scalable, i.e. be able to exploit the potential for expansion and other parts of production such as logistics, production and supply and disposal facilities.
The solution approach
Author Dennis Trosdorff with a view of one of the numerous displays that employees can use to view system details at any time.
© Actemium
When selecting the system and layout, Krombacher, together with Actemium, opted for the zenon software platform from Copa-Data. The advantages include the extensive PLC driver library supplied and the suitability for visualization and control of equipment and processes as well as for data acquisition and evaluation.
In a second step, all existing and new variables were viewed and recorded in order to obtain a complete overview using a variable list. This included the SQL data packages from the old system, meter data as XML and new data from other systems. Actemium developed a program that used the data previously compiled in Excel to automatically generate the SCADA projects, including all data on projects, PLC drivers, data points, plant models and archives, as well as the interaction with external systems.
This reduced the workload and significantly reduced transmission errors. At the same time, all changes can be made by revising the Excel lists, making it easier to document changes. A newly installed Krombacher bottling line served as a template to demonstrate the potential of the new system landscape to the customer.
Two redundant servers connect the new and scalable IT architecture via various interfaces with classic and web clients, the project planning environment, database servers, the data warehouse and ERP systems. This also enables detailed and centralized reporting.
Everything in view
Twelve filling lines and connected ancillary systems are integrated into the new system landscape.
© Actemium
Following the successful implementation, Krombacher can now monitor various areas in clearly structured dashboards - from the individual bottling lines and energy data to master data maintenance, production data acquisition and reporting. The monitoring of the individual areas includes
Filling lines:
  • Complete lines with an overview of current orders, real-time data and OEE (Overall Equipment Effectiveness),
  • Status of individual machines such as pushers, fillers or packers with live and trend data (including actual and target values),
  • Alarm overview with automatic recording of faults and downtimes and their classification (particularly important for determining the OEE).
Energy data acquisition and management:
  • Overview of live data evaluation,
  • Graphic display of the distribution of electricity consumption in real time, e.g. operating values of the combined heat and power units (CHP units) incl. proportion display of electricity generation (CHP units and energy suppliers) and consumers (e.g. brewhouse and bottling plants),
  • air flow rate shares of compressors and the supply of individual plants.
Centrally managed reporting:
  • Central management of reports on plants including rights management to restrict them to specific employees,
  • automatic filing and sending of reports in the system,
  • Structured search of reports by plant area.
Master data maintenance and production forecast:
  • Management of product and plant master data for each plant including target and set output as well as consumables,
  • Forecast calculations according to daily, weekly and shift plans,
  • Direct adaptation of shift plans,
  • direct transfer of product planning from SAP.
Full transparency
Rainer Bub (l), Project Manager at Krombacher, and Ralf Kirchner (r), Project Manager at Actemium, have full transparency thanks to the extended monitoring.
© Actemium
The new system landscape planned and implemented by Actemium gives Krombacher significantly greater transparency regarding the process and machine status of its twelve bottling lines. As the beverage producer can not only read out data, but also write it back to control systems, the level of automation in production can also be increased. Information from different production areas can be linked together to show dependencies and effects, which makes production and operational planning easier, faster and therefore better. For example, production capacities can be compared with each other in real time and thus better coordinated. Employees can view system details on displays in the production halls at any time and adjust and react to parameters as required.
Actemium has designed the system to be highly scalable and expandable. For example, additional production areas and other Krombacher sites could be integrated in order to have the option of monitoring, visualization and reporting across all sites. The entire switching logic of the energy supply could also be integrated: on the one hand for sequencing the CHP units and refrigeration systems, for example, and on the other for automatic load shutdown. So the potential is far from exhausted, which makes it clear: Krombacher is ready for the future.
