Adamczewski at the SPS 2022
Manage 32 measuring stations centrally
Adamczewski Elektronische Messtechnik presents the AD-MM 500 FE monitor module. The monitor module can be configured for data output and for reading out individual or multiple measuring points.
The device from Adamczewski combines a display and control unit as well as a data logger in a compact housing for front panel installation. It acts as a Modbus master and processes the signals from up to 32 different measuring stations. The module can also be parameterized, whereby setups can be preconfigured and, if required, loaded using a PC. The recorded values can be shown graphically in different ways on the integrated display.
At the same time, the data is logged according to selectable time or limit value specifications, so that manual checking is no longer necessary. The monitor module for control cabinet mounting is suitable for a wide range of measuring devices and applications - this is made possible by the configuration options and the RS485 bus with Modbus RTU protocol as the communication standard.
SPS 2022: Hall 7A, Stand 131
