Operating and monitoring:
Quelle: Graf-Syteco | Inka Krischke,
Flexible thanks to ball head mount
Graf-Syteco is launching the D3510 operating and control unit from the 'D series'. In contrast to the devices available to date, which are intended for installation in a control panel, this device has a housing with a ball head holder on the back.
© Graf-Syteco
This means it can be flexibly positioned in the driver's cab of a mobile machine, for example. For use in harsh environmental conditions, the operating device meets all relevant standards, for example from the DIN EN 60068-2 series of standards. This also includes the extended temperature range of -20 to +70 °C and protection class IP65. The operating device is equipped with a 32-bit ARM9 processor with 64 Mbyte RAM, 32 Mbyte Flash and 8 kByte FRAM. The 7-inch display has a resolution of 800 × 480 pixels. The operator can make entries using the twelve illuminated short-stroke keys and the rotary encoder. Two CAN interfaces as well as an Ethernet, RS232 and USB interface are available for integration into an automation architecture. The operating device is supplied together with the 'Graf-Design-Studio (GDS)' software, which can be used to program all functions. Programming with Codesys or in C is also possible.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
