OPC UA server
Quelle: Inosoft,
Flexible selection of data points
Inosoft introduces new functions such as the OPC UA server VisiWin. It accesses all variables managed in VisiWin via the OPC UA interface.
© Inosoft
This allows various application scenarios - for example as a data source for higher-level MES/ERP systems, IIOT gateways or for machine-to-machine communication. A configuration option in the VisiWin project can be used to flexibly decide which data points are to be provided. To implement OEM systems, Inosoft has developed a VisiWin 7 server based on .NET Core. .NET Core offers broad support for different platforms and architectures. The new server is therefore a platform-independent alternative to the existing Windows server and is also suitable for integration into embedded systems.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
