ifm electronic at the SPS 2023
Displays for mobile machinery
The 'ecomatDisplays' with a 4.3-inch screen diagonal from ifm electronic offer a high-resolution display and good readability even under extreme viewing angles or difficult lighting conditions for use in mobile machines.
© ifm electronic
The displays from ifm electronic offer the CAN bus with its various protocols, which is important in mobile machinery. An Ethernet or USB interface is also available as an option. For user input, there are six freely programmable, backlit function keys and a cross rocker with a central confirmation key. These input options can also be operated with gloves. The ARM dual-core processor with 1.4 GHz and 1 Gbyte RAM offers sufficient performance even for demanding visualizations. The user can program these with Codesys 3.5 and draw on an ifm library of software modules. Alternatively, visualizations can also be created with Qt on the Linux-based operating system. The die-cast aluminum housing complies with IP67.
Hall 7A, Stand 246+302
ifm at the SPS 2023
Free IIoT software
The first step in IIoT projects is usually the digital connection and subsequent configuration of the devices - for example with IO-Link devices and the 'moneo configure' software from ifm. This is now available free of charge.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
