GMC
Testing battery storage systems
With the Metracell BT Pro portable battery tester, Gossen Metrawatt offers a test system for testing battery storage systems for DC systems.
© GMC
In addition to the required capacity tests, it can be used to carry out maintenance work in order to detect premature ageing of the battery and ensure the predicted performance. For this purpose, the tester measures the electrical and electrochemical resistance, which increases with increasing stress and battery ageing.
According to GMC Instruments, the battery tester can also be connected to a temperature sensor. Other functions include interval measurement, which can be used to simultaneously record the voltage of the battery block or system (up to 600 V) and the charging/discharging current. All required measurement tasks are supported by an integrated RFID transponder system.
Hesch
Incorrect measurements excluded
The HE 5422 differential pressure regulator from Hesch has been redesigned: Thanks to the pre-coating functionality, the cleaning process is significantly simplified and the Datahold function eliminates incorrect measurements.
Janitza electronics
Say goodbye to load peaks
Peak loads are expensive. Even one-off 'slips' cause additional costs in the five-figure range. However, the obvious solution of temporarily switching off large consumers such as heating systems must not compromise process reliability. Modern...
Manner sensor telemetry
Two into one
Manner offers the XtreMA two-in-one dual-range torque transducer for recording multiple rotating torque ranges. This transducer has two torque ranges with two separate and independent signal outputs.
Meilhaus
Field-ready and battery-powered
Meilhaus offers the 'Metrahit' AM, PM and IM multimeter series from GMC-I/Gossen Metrawatt. The 'AM' series provides TRMS (True Root Mean Square) universal multimeters with 12,000 digits digital display and consists of the 'AM Base', 'AM Pro', 'AM...
Endress+Hauser
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flowmeter from Endress+Hauser is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the...
Heidenhain
Long awaited
Heidenhain used SPS 2019 to present EnDat 3. Herbert Reiter, Product Manager Encoders and Electronics at Heidenhain, explains what the enhanced interface for rotary encoders, angle encoders and linear encoders can do.
