Endress+Hauser
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flowmeter from Endress+Hauser is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the supplier.
© Endress+Hauser
The integrated pressure and temperature measurement minimizes the installation effort, and the multi-parameter measurement allows both mass and standard volume to be measured and output directly. The integrated gas analysis function also makes it possible to calculate the calorific value, energy flow, molar mass, density and viscosity, for example.
The flowmeter is SIL-certified and, together with 'Heartbeat Technology', offers traceable device verification without interrupting the process.
Hesch
Incorrect measurements excluded
The HE 5422 differential pressure regulator from Hesch has been redesigned: Thanks to the pre-coating functionality, the cleaning process is significantly simplified and the Datahold function eliminates incorrect measurements.
Endress+Hauser
Digital twins on the rise
Digitalized processes along the entire value chain require a digital twin. Behind this virtual image of a real object is a wealth of data and algorithms that are used to simulate, control and improve processes.
