Fotric/ Meilhaus
Portable thermal imaging cameras
Ti5 and Ti7 from Fotric are portable thermal imaging cameras for professional thermography. With their robust design, an IR resolution of 384x288 or 640x480, a sensitivity of <30 mK or <40 mK and a user-friendly interface, they are an intuitive solution for industrial inspections.
© Fotric / Meilhaus
The cameras are supplied with a 44° lens. They combine thermal contrast autofocus, laser-assisted, continuous and touch autofocus as well as manual focus for fast, precise and quiet focusing. Thanks to seamless alignment of thermal and digital images, they enable precise analysis. The T-TWB histogram temperature display automatically adjusts the palette band based on the pixel distribution across the temperature ranges and provides a clear visualization of the temperature distribution. IREdge contour detail enhancement enhances the visual impact of object contours and edges so that the user can better distinguish them from the background. The devices are available from Meilhaus.
Baumer
AI quality inspection made easy
AI will also bring fundamental changes to industrial applications. What is interesting is the gap that is opening up between this realization and practice. Although most companies see the potential of AI, only a few dare to use it.
VDMA
Uncertain times for machine vision
Based on the latest VDMA surveys, the European machine vision industry recorded a 7% decline in sales in 2023. The VDMA Machine Vision department expects a further decline in sales of 3% for the current year.
Meilhaus
DC power supplies up to 200 W
B+K Precision's 'BK9240' series devices are universal DC power supplies whose multi-range power supplies extend the rated power from a point to a curve, delivering up to 200W over a wider range of voltage/current combinations.
