Meilhaus Electronic
DC power supply unit with automatic switchover
With the N8900A series devices from Keysight, Meilhaus Electronic now also has the top models of the N DC power supply series (N5700A, N8700A, N8900A) in its range.
© Meilhaus Electronic
The devices in the series are programmable DC power supply units with an autoranging output and a total output of 5 kW, 10 kW or 15 kW. The series has 28 models available in 14 different voltage, current and power combinations in 208 V(AC) or 400 V(AC). A simple parallel connection of several devices results in a power supply with over 100 kW output. The built-in parallel connection function (autoranging output) enables programming as with a single large power supply unit, so that it is not necessary to program each power supply unit individually, according to Meilhaus . The DC power supplies offer multiple standard I/O interfaces and a compact 3U design that saves rack space.
Meilhaus
DC power supplies up to 200 W
B+K Precision's 'BK9240' series devices are universal DC power supplies whose multi-range power supplies extend the rated power from a point to a curve, delivering up to 200W over a wider range of voltage/current combinations.
Ateg
Keyboards with glass surface
Ateg offers capacitive PC keyboards with a glass surface from the French manufacturer Tactys. The glass of the user interface is made of 3 mm thick, hardened white glass, which is robust against mechanical influences.
Most read
The top articles in June 2024
The most-read articles in June illustrate the power of the automation industry. Read more about the technologies and strategies that are gaining ground in areas such as networking, robotics, safety and the process industry.
Data analysis
Close and yet so far away
Due to complex processes and high cost pressure, system operators and plant operators can hardly avoid analysis at the edge: only by processing the measurement data close to the process can the process be intervened in real time in the event of a...
Meilhaus
