Turck
Fast strain gauge evaluation device for hazardous areas
Turck is expanding its interface portfolio with a fast strain gauge evaluation device for force measurement applications in hazardous areas.
The 'IMX12-SG' from Turck
© Hans-Turck
The 'IMX12-SG' has a repeater function and can be used for signal conversion in the event of resistance changes on strain gauge bridges. According to the supplier, this is a unique selling point on the market - as is the response time of less than 10 ms, combined with a flexible output circuit via DIP switch and galvanic isolation in a 12.5 mm narrow housing. Turck relies on the principle of galvanic isolation between hazardous and safe areas for the device. This prevents interference or equalizing currents that can occur due to potential carry-over. As with all devices in the 'IMX12' series, operation in potentially explosive zone 2 is permitted in a protective housing. A wide supply voltage range of 10 to 30 V(DC) also enables use in applications with battery operation, for example in temporary, mobile facilities.
Turck
Paving the way for digital transformation
Automation solutions from Turck support the profitability, efficiency and sustainability of machines and systems. In this way, they not only increase competitiveness, but also contribute to more environmentally friendly production and intralogistics.
