Turck
Inductive IO-Link sensors with analog output
Turck is expanding its sensor range to include measuring inductive sensors with IO-Link and analog output for flush and non-flush mounting.
According to the manufacturer Turck, the 'BI11-CK40' and 'NI11-CK40' models offer significantly improved linearity and accuracy including temperature compensation over a temperature range of -25 to +75 °C thanks to the integrated microprocessor. The sensors have a classic, adjustable voltage output from 0 to 10 V on the one hand and an additional switching output that can be freely parameterized via IO-Link and provides measurement data and diagnostic functions for predictive maintenance on the other. In addition, the simple parameter transfer via IO-Link facilitates sensor replacement in the event of a fault and minimizes downtimes in production. With a range of up to 25 mm and a linearity deviation of less than 1% for the flush version and less than 3% for the non-flush version, the robust IP67 sensors are suitable for a wide range of applications, for example in the mechanical engineering, packaging, energy and automotive sectors. The cuboid CK40 design creates space for space-saving, flexible and easy-to-implement mounting solutions. The sensor head can be positioned in five directions using the tool supplied.
