Compmall
Two full-size graphics cards can be integrated
The GP-3000 from Compmall can be used as a scalable embedded PC or as a GPU computer with plug-in GPU expansion boxes and can be equipped with up to two full-length graphics accelerator cards.
© Compmall
The basis is a processor of the 9th/8th gen. Intel Xeon/Core or 8th Gen. Intel Pentium/Celeron. There are 20 processor variants to choose from. The high-end solution is the Intel Xeon E-2278GE processor with eight cores and a clock frequency of up to 4.7 GHz. For lower requirements, the 8th Gen. Intel Celeron G4900T with two cores and a clock frequency of up to 2.9 GHz. The graphics chip is adapted to the processor: The UHD 630 is provided for Xeon and Core, the UHD 610 for Pentium and Celeron. Both graphics chips in the Compmall PC allow the control of three independent displays via HDMI, DisplayPort and VGA.
Five Ethernet ports are available; the GbE ports can be increased by a further four by integrating a CMI module. Two SIM card slots ensure connection to wireless networks, and a WLAN card can be plugged in via a Mini PCIe slot.
Compmall
Embedded PC DV-1000
The DV-1000 embedded PC from Compmall is fanless, robust and compact. With a mounting kit, the PC can be attached to the DIN rail to enable applications in factory automation, logistics for controlling autonomous mobile robots or image processing
