Compmall
Embedded PC DV-1000
The DV-1000 embedded PC from Compmall is fanless, robust and compact. With a mounting kit, the PC can be attached to the DIN rail to enable applications in factory automation, logistics for controlling autonomous mobile robots or image processing
The compact industrial PC has Intel Core processors of the ninth or eighth generation, with a total of twelve i-Core processor variants to choose from, two Pentium and two Celeron CPUs. One memory slot is reserved for 2666 MHz DDR4 SO-DIMM with a capacity of up to 32 GB.
Sockets for line-out and mic-in form the analog audio interfaces. The fastest configurations currently available are the DV-1000 equipped with Intel Celeron G4900T, Core i3-8100T, Core i5-8500T or Core i7-8700T.
